Timing and total advance ?
  • Thread starter Thread starter 88dragtop
  • Start date Start date Sep 19, 2007
88dragtop
198
Glastonbury,CT
Sep 19, 2007
  • Sep 19, 2007
I'm trying to figure out my total timing advance of my stock 289 dist with pertronix conversion. I know you disconnect the vac. to check base but do you also for checking the total? Is there both centrifugal force(mechanical) advance and vac. advance? If I rev w/o the vac. I don't get any change. My buddy said I need to check it w/o vac. to simulate WOT but I don't see how it's going to mechanically advance and overcome the vac. diaphram(it gives a good amont of resistance). I am using the correct port on the pass. side of carb.(Holley 600). Been out of the carb'd stuff so long I don't remember.
thanks
88dragtop
198
Glastonbury,CT
Sep 19, 2007
  • Sep 19, 2007
The dist. is still in the car but I pulled the vac advance stuff off so I can see the mechanical advance mechanism. It isn't rusty at all but I just can't seem to get it to move, it's not wired or locked that I can see from looking down in. Springs and counterweights are there. You guys have any ideas what to try to free it up. I'm assuming if someone locked it out I would see something like safety wire or a screw?????
blown65
1,938
Queen Creek Arizona
Sep 19, 2007
  • Sep 19, 2007
Sure sounds like its locked out. Make sure where it does move that there isnt some sort of little bolt/nut locking it out.
88dragtop
198
Glastonbury,CT
Sep 19, 2007
  • Sep 19, 2007
I sprayed some penetrant down in the hole under where the rotor goes on because that's where it should rotate from the shaft attached to the dist gear. Car runs OK just that I'm going to a drag day on Fri. and won't be able to fix before then probably, I'll just set full advance and plug the vac. for the track. I can't wait to feel the extra 20 degrees of timing I've been missing out on WOT. Now I understand some of the flat top end response, thought it was a carb issue.
I need to get my EFI conversion done, F this crap
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
R
1974 Datsun 620 pickup / 5.0L HO
  • RJH46
  • Aug 24, 2025
  • Other Auto Tech
Other Auto Tech Aug 24, 2025
R
Timing with Pertronix III ?
  • red_mach1
  • Jan 1, 2024
Classic Mustang Specific Tech Jan 7, 2024
Blackhawkxx
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
