Timing Assistance
  • Thread starter Thread starter DissFigured
  • Start date Start date Dec 28, 2005
DissFigured
320
Dallas, TX
Dec 28, 2005
  • Dec 28, 2005
I am not sure how to set my timing. I have the Ford Shop Manual. I think it is the correct one. It is the 1965 Comet, Falcon, Fairlane, Mustang Manuel. I am finding very little in the book about actually setting the timing. I see several references where it shows the notches used for the timing, but I don't see any specifis passages to how I am to use my timing light and what I am supposed to be looking for?
Anyone feel like walking me through this or happen to know what page it is on that I am not seeing?
It is a 1965 coupe w/ a 289
HistoricMustang
2,359
Confederate States of America
Dec 28, 2005
  • Dec 28, 2005
Come on guys/girls and pitch in.....................
HistoricMustang
www.historicmustang.com
D
DJCarbine
392
  • Dec 28, 2005
I ask for so much help, I decided to give a little
On your damper, if it is the old 40 odd year old one, there are timing marks. They might be hard to see due to surface rust and gunk, just take a cleaning solution and a rag and try to clean it up a little. Worst comes to worst, run your finger on it carefully and find the grooves where the timing marks are. Look down on it from the drivers side, there should be a pointer jutting out at around the 1-2 o'clock position on the timing cover. This is the timing mark, and the marked intervals on the camper are the timing degrees. The manual prolly calls for about a 8-12 degrees before TDC, which you should be able to identify on the damper. Loosen the nut holding the dizzy in place a little, enough to turn it, but not so that it can spin around freely by itself.
Connect the timing light to the + and - terminals on the batt, and there should be a lead from the light that you clamp onto the number one plug wire. This is the closest plug near the radiator on the passenger side, it should be marked on the dizzy/manifold where number 1 is. Fire the car up and point the light down from the drivers side onto the timing mark/damper.
The light will strobe everytime plug 1 fires, and you will be able to see where the marks are on the damper and compare them to the pointer on the timing cover. Whatever you see on the damper in the strobe is where the timing is currently set at.
Turn the dizzy SLOWLY to change.
Some things to think about... the outer ring on the damper can slip, giving you an innacurate reading. How to check for this:
Pull number 1 plug. Stick a straw in the cylinder thorugh the hole. Turn engine by hand/breaker bar on damper pully bolt untill you feel the cylinder is at its highest stroke. Compare the TDC mark on your damper to the timing mark. It should be right on it. If it is not, turn the engine over again to make the cylinder fall and rise again. Re-check.
I most likely left something out/fubar'ed something, feel free to correct me
krash kendall
1,258
Aldergrove, B.C. Canada
Dec 28, 2005
  • Dec 28, 2005
Dissconnect and plug the vacuum advance line to the distributor before setting your timing or you will get very frustrated. Hook it up again after.
Did you put in that new pertronix unit you bought a while back?
And yes, 8-12 degrees will probably work best for you. If the engine pings under load, when accelerating or hill climbing then back it off little.
D
DJCarbine
392
  • Dec 28, 2005
Damnit, I knew I forgot something
I am watching monty python and the holy grail... I'm a little off in another land right now
"what floats in water"
"little tiny rocks!"
"Gravy!"
"APPLES!"
DissFigured
320
Dallas, TX
Dec 28, 2005
  • Dec 28, 2005
I didn't get the pertronix one.
I got an accel (i think) It eliminats the points. Downside is it still has moving parts. Seems to work very well though.
Assumption "dizzy" Is this new street lingo for distributor?
Like if a buddy has distributor problems, I can say yo dawg, it's the dizzy fo ****zle
What does TDC stand for?
D
DJCarbine
392
  • Dec 28, 2005
Actually, I cant spell distributsomething, so I use "dizzy" or rotating spark allocation unit
TDC stands for Top dead center, when the cylinder number 1 is all the way at the top of its stroke
DissFigured
320
Dallas, TX
Dec 28, 2005
  • Dec 28, 2005
Well Cool!
That was about the eaiest thing I have done on this car. I got it last march, and I have been driving unknowingly with no distrubutor hold down bolt. A friend of mine was looking at the battery and he say the "dizzy" w/o that bolt and said "Go home and never drive it again until you get that bolt."
So, it came in today and wanted to set the timing before I locked it down. None the less, it Idles and accellerates smoother. I set it between 8 and 12. The only downside is I really dug that sound where it sounded like it might die while idling. It sounded mean. That is gone but I somehow suspect that the car is now less likely to actually die while idling.
DissFigured
320
Dallas, TX
Dec 28, 2005
  • Dec 28, 2005
Out of curiosity, why did I disconnect and unplug that vacuum tube. I did it, but I don't know why.
D
DJCarbine
392
#10
  • Dec 28, 2005
  • #10
Did you adjust the idle speed too? Changes in timing often effect the idle speed, I like to idle around 550-600 just because it sounds a little meaner
You disconnected the vacuum tubes because the distributor has a vacuum operated spark advance that will change your timing according to how much vacuum the engine is pulling through the spark advance port. If you leave it connected, the timing may be off when you adjust it, because theoretically the spark advance could change the timing. Shouldn't at idle, but I was always told to disconnect it.
Will I feel a difference
  • 90Stanger302
  • Mar 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 13, 2026
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
G
Intro and FB questions
  • gflat65
  • Nov 16, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
horse sence
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
