Timing Bump Prep
  • Thread starter Thread starter forzalife
  • Start date Start date Feb 15, 2014
F
forzalife
186
West Palm Beach, Florida
Feb 15, 2014
  • Feb 15, 2014
Hey im about to bump my timing for the first time.i have a bit less than half a tank of regular octane gas. Should I wait till my gas runs out to bump my timing and then fill with premium? Should I fill with premium before bump?
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,254
204
South Jersey
Feb 15, 2014
  • Feb 15, 2014
Top it off with sent fresh fuel and bump the timing up. Be sure to listen for pinging! I would start at 12* with the spout out and go up a degree at a time. Most find 14*base to be the sweet spot.
F
forzalife
186
Feb 15, 2014
  • Feb 15, 2014
Im not gonna need more than regular octane at 14* am I?
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
Feb 16, 2014
  • Feb 16, 2014
Yes you should run 93, ttop is saying to top it off with 93. I put paint marks on 10, 12, 14* that way it's easier to see
Grabbin' Asphalt
2,029
310
124
Atlanta, Ga
Feb 16, 2014
  • Feb 16, 2014
Remember if you have a half tank of 87 and you put 93 in you will half the mix to 90 octane.
F
forzalife
186
Feb 16, 2014
  • Feb 16, 2014
Thanks guys ima go waste some gas and fill with premium
F
forzalife
186
Feb 16, 2014
  • Feb 16, 2014
But hey guys check out what these guys have to say about this http://m.mustangforums.com/forum/showthread.php?t=423225&styleid=8 my goals are to increase hp and these guys are saying that I shoild advance timing only to the point of no engine knock with regular octane gas... their saying more advance increases hp but the higher octane negates this.. what do u guys think?
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,254
204
South Jersey
Feb 16, 2014
  • Feb 16, 2014
The higher octane facilitates you running more timing and decreases the threshold for detonation. I would run the premium fuel with the timing turned up personally!
Reactions: A5literMan and f8tlfiveo
Grabbin' Asphalt
2,029
310
124
Atlanta, Ga
Feb 16, 2014
  • Feb 16, 2014
Sener
You've got a couple options, you could....
a. Use 87 and advance the timing as far as you can and save $ at the 87 timing threshold. Which it will change once you reach Hot weather, sitting in traffic during summer etc, then you would have to back it off to still use 87.
b. Use a middle or higher octane 89, 90 or 93 during the summer to help you to Not keep changing the timing when Hot weather hits.
c. Use 89 as a good middle one and add the 93 during Hot summer months.
d. Use 93 and find the timing limit, while utilizing the highest compressed explosion in your cylinders for peak HP potential.
Remember the higher the octane is, the less resistant to pre~detonation. Extremely critical in non~forged pistons, power adders like NO2 or blowers. You can melt things quick if you do not regulate pre~detonation.
If I'm choosing for most possible HP's in a motor, similar to a SC or blower, compression in the cylinders is what I want. So taking 87 igniting sooner over ~ 93 igniting later(more compression) is leaving HP's on the table. How many, who really knows We need a dyno run using both octanes and their timing limit threshold to find out the true answer to the added compression pay off with 93. We need to start googling....lol
Reactions: forzalife
F
forzalife
186
Feb 16, 2014
#10
  • Feb 16, 2014
  • #10
Grabbin' Asphalt said:
Sener
If I'm choosing for most possible HP's in a motor, similar to a SC or blower, compression in the cylinders is what I want. So taking 87 igniting sooner over ~ 93 igniting later(more compression) is leaving HP's on the table. How many, who really knows We need a dyno run using both octanes and their timing limit thredhold to find out the true answer to the added compression pay off with 93. We need to start googling....lol
Hmmm well I live in south florida where most of the year its warm, hot, or baking hot.. so I guess ill go with d and put 93 octane. Right now its pretty cool so im gonna bump to 12 on 87 till my gas runs out then switch to premium.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,360
211
114
Ohio
Feb 16, 2014
#11
  • Feb 16, 2014
  • #11
I run Premium and have my timing bumped to about 13 1/2.
Blaise805
88
#12
  • Feb 17, 2014
  • #12
I have been reading about this and I'm wondering if there is a noticeable difference in performance on a stock engine when the timing is advanced?
Decipha
221
36
39
New Orleans, LA
Feb 17, 2014
#13
  • Feb 17, 2014
  • #13
keep in mind this only applies to a stock tune/engine
You go changing heads and you may need much more base timing with no tune
theres an mbt reference chart in my sig to get you in the ballpark
Decipha
221
36
39
New Orleans, LA
Feb 17, 2014
#14
  • Feb 17, 2014
  • #14
Nvm i dont have a sig
http://www.efidynotuning.com/mbt.htm
Blaise805
88
#15
  • Feb 17, 2014
  • #15
I checked out your site.I had no idea there was this much info was available especially for a stock engine
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,254
204
South Jersey
Feb 18, 2014
#16
  • Feb 18, 2014
  • #16
I've seen as much as 20 rwhp just by bumping the timing and bypassing the coolant from the egr removed air silencer etc. that's bang for the buck when we are only talking about your time and not $ spent on parts!
Blaise805
88
#17
  • Feb 19, 2014
  • #17
I might have to check this out!
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
F
Difference between 83-86 EFI and 87-97 gas tanks?
  • ForeverDrivin
  • Mar 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 30, 2026
ForeverDrivin
F
F
Car dies on bumps and when braking
  • Feckl
  • Jul 14, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jul 19, 2025
squeak93
68 fuel gauge maxes out at half
  • connella08
  • Sep 5, 2025
Classic Mustang Specific Tech Sep 8, 2025
connella08
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
