timing chain/push rods
  • Thread starter Thread starter ALMOSTFINISHED
  • Start date Start date Jun 10, 2004
ALMOSTFINISHED
315
Westchester County NY
Jun 10, 2004
  • Jun 10, 2004
I might be getiing some twisted wedge heads for my 88 gt, i have the track heat upper and lower right now. I also want to get the trick flow stage 1 cam. I was wondering what length push rods to use and also what timing chain to use. Im looking at the 24 pound injectors too. any suggestions?
thanks
Nick
skeezo83@hotmail.com
408stroker5.0
The world would be a better place if all males jus
Mar 10, 2004
639
Bonnyville, Alberta, CANADA
Jun 10, 2004
  • Jun 10, 2004
Use a Roller Timing Chain & Gear's for sure. Comp, Cloyes, FRPP and JP Performance (Yella Terra) make good set's for your 5.0. As for pushrod length I highly recomend getting an Adj. pushrod length checker (Comp Makes Decent Ones $14.00) to determine the exact length you need.
ironmedic
1,361
Puyallup, WA
Jun 10, 2004
  • Jun 10, 2004
you can find out the pushrod length on the trickflow website or the box!
408stroker5.0
Mar 10, 2004
639
Jun 10, 2004
  • Jun 10, 2004
True... but I alway's say it's good to check. It's happened to me twice were I have went with the manufacture's recomended push rod length and they were off by a bit. It's impossible for a manufacture to have the correct length for every engine out there as all combo's are different. They are alway's close but should be used more for reference I feel. An Adj. Pushrod length checker is the only way to go.
ALMOSTFINISHED
315
Jun 10, 2004
  • Jun 10, 2004
Thank very much for the info everybody. I'm on a mission to get this going. I was behind my car yesterday with my friend driving and saw the smoke on decelleration so I really want to get this done. Thanks again
Nick
Ourobos
260
Jun 13, 2004
  • Jun 13, 2004
I have the tfs stage 1, and reused stock pushrods. They fit perfect.
saleenx029
117
Cincinnati, Ohio
Jun 14, 2004
  • Jun 14, 2004
Definately get a adj pushrod and check the pushrod lenth no matter what the company says, I have had troubles with this before also.
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
