I'm outside installing the timing chain that came with my Trick Flow H/C/I kit. It's part number 78520T whcih I believe is a Dynaroll billet set.
In the kit it states that the bronze bearing that is included with the set requires that you countersink the thrustplate bolt holts so that the supplied screws will sit slightly below the service of the thrust plate.
I compared the old timing set to the new timing set and it appears that I have to use the bronze bearing and make these modifications. The thing is, every person I had talked to about doing this install had never mentioned having to do this, so I'm questioning if I really have to use the bronze bearing or not?
I'm not doing a rebuild or anything on the block. It only had 60K on it and has seen nothing but synthetic oil and 2000 mile services (I'm obsessed). Compression tests came back + or - 1 PSI across all the cylinders so the block seems almost as good as stock. As far as the parts go, I'm installing the Trickflow Street Heat H/C/I setup (with 3/8" spacer), BBK 1 5/8 Longtube Headers, BBK Off-road x-pipe, 255LPH Walboro pump, New Water Pump (of course), and underdrive pulleys. It's a cobra so it already has the 24lb injectors, and I also have the mod's in my signature to go with the install. I also went ahead and cleaned/slightly enlarged the port entrys on the upper and lower intake with a die grinder, and gasket matched the whole kit. I also cleaned up the exhaust ports on the longtubes since there was a good amount of weld splatter on the inside. I was thinking about getting a AFPR, but since I will be getting it dyno tuned, and will be purchasing a tweecer (or an AFM unit if I can get the money) in the next month or so, I'm holding off on that.
Good luck, take care.
