  • SN95 4.6L Mustang Tech
timing chain question
  • Thread starter Thread starter Chucks98
  • Start date Start date Mar 1, 2012
C
Chucks98
West Newton,PA
Mar 1, 2012
  • Mar 1, 2012
Ok i just put the timing chains back on the engine after swapping the heads. The right(pass) chain gets slack in it about every 4th revolution of the cam gear. It stays tight on the lower guide, the tensioner guide, but will sag off the upper. The left side stays tight.
Is this normal since there is no oil pressure for the tensioner? Or perhaps did i stretch the chain? When i swapped the cams last year i never noticed any slack.
The car has 76k miles on it and only 42oo since the cam swap
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Mar 1, 2012
  • Mar 1, 2012
As long as it doesn't go slack to the point where it could skip teeth, I would say it is OK. The reason is as you guessed that there isn't any oil pressure to pump up the adjusters.
A
Engine 04 GT timing chain issue
  • AwesomeX1103
  • Sep 3, 2025
SN95 4.6L Mustang Tech Nov 5, 2025
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
Timing chain tensioner? (youtube video link)
  • slxne5.0
  • Sep 7, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 7, 2025
slxne5.0
D
Rockers, lash adjusters and timing: help with parts (4.6 2v)
  • dvigAtel
  • Nov 1, 2025
  • Other Auto Tech
Other Auto Tech Nov 1, 2025
dvigAtel
D
M
Timing chain loose on top passenger side
  • MustangD0M
  • Mar 18, 2025
1996 - 2004 SN95 Mustang -General/Talk- Mar 26, 2025
89ripper
