- Jun 24, 2005
- 35
- 0
- 0
I have an 02 GT. About 1 1/2 months ago I double gasketed the oil filter when I changed the oil. Oil didn't leak out right away, the filter loosened up after about 25 miles of driving. Anyway I noticed I had no oil pressure pulled over figured out what was happening changed oil filter and added 5 more quarts. I ended up with a rattling sound coming from the front cover and after several other's opinions replaced the timing chains and tensioners(with steel). I drove for about 2 days and noticed the sound had come back mostly around 2000 rpm. It would go away if I applied gas or would go up a hill. The consensus was that I may have gotten a bad batch of tensioners. I was told this wouldn't hurt anything just an annoying noise. I never felt like the car lost power as seemed just as stromg as before. Fast forward to earlier this week. This time on my drive home about 70-75 miles an hour on the highway I could hear the clatter much louder. I also noticed the oil pressure gauge was going up and down. All the way to nothing and back up again, several times every few seconds. I pulled over shut it down and checked the oil. It was in between the min and max marks about halfway. I started it back up and drove to the nearest store and dropped another quart in it. While driving to the store the oil gauge stayed steady. Did so on the way home as well. I emptied the oil and put another 5 quarts in it. I tried my best to measure the amount of oil that I took out and it looked like 5 plus quarts. Drove to work the next day and it seemed fine though the noise was still louder than normal. Drove home that day and the same thing happened again with the guage. I pulled over again and took the oil cap off the cam cover. I had wisp of smoke coming out of it like it wasn't getting oil. Without checking I dumped another quart in it and drove home. This time as I was gunning it to get back into traffic on the highway I definitly felt a loss of power. Got home let it sit about 1/2 hour checked the oil. Level was slightly below max. I grabbed a piece of wood and did the old redneck stethoscope thing and can definitly hear clatter when the wood is placed at the front of the cam covers on both sides. When placed at the rear of the covers the noise is there but not near as loud. I believe the tensioners are shot again but I have my doubts about the oil pump as well. Is it possible that the pickup is covered up and that's causing the fluctuation? If the tensioners themselves were not a bad set from Ford then something is causing then to go bad and oil starvation to me would be the biggest culprit. I do have new tensioners coming along with new arms and guides. I need to know if there is a way to check the oil pressure without resorting to buying a mechanical Autometer gauge. Any ideas?
I really do appreciate the help fellas.
