Timing chain tensioner issue/oil pump?
tomustang said:
I tried that method when my bearing spun, nothing showed up in the oil, I even tore apart the oil filter and it was clean. It doesnt work all the time. Sure as hell had flakes hanging around in the oil pan and heads though
You are right, it won't work everytime, but it is a dead giveaway when it does.
the98stang said:
Do a compression test just to be sure...
Compression check won't find a bearing problem. About the only way to test for it in the early stages (before it starts knocking) without tearing into the engine, is to have an oil analysis done. But you can pretty much bet that if it won't hold oil pressure, the bearings are on their way out.
