timing cover problems
  • Thread starter Thread starter natedawg3649
  • Start date Start date Aug 23, 2007
N
natedawg3649
10
MS
Aug 23, 2007
  • Aug 23, 2007
I'm rebuilding my 302 and have come across something i just do not understand. The timing cover that came off is different than the one i ordered from latemodelrestoration.com but it said it was for 5.0 w/efi. I don't understand the difference in a standard rotation and a reverse rotation waterpump. I just want to make sure i install the right timing cover along with the right water pump and make sure everything spins in the right dirrection. The only thing that will be missing will be the smog pump so everything will be routed pretty much the same.
this is the part# that i ordered ( LRS-6019B )
this is the type that i took off the engine, Part# M6059D351
Can someone tell me the difference and if it matters which one i use and what is the best waterpump to go with either standard or reverse rotation
bullitstang1313
713
Indianapolis / Columbus, Indiana
Aug 23, 2007
  • Aug 23, 2007
If you are using the accessories from a fuel injected 5.0l engine, you will want to go with the reverse rotation waterpump. It has to do with the way the belt is rounted. As far as your timing cover question, the top cover is for fuel injected 5.0l's the bottom picture looks to be for the older 302's with the block mounted fuel pump. Also the oil dip-stick is installed in the timing cover on the older 302's. You can see the spot on the timing cover just above the bottom left bolt hole.
samickguy15
404
Delavan, IL
Aug 23, 2007
  • Aug 23, 2007
Beat me to the punch with all of that. It looks like your new one will be AOK
N
natedawg3649
10
MS
Aug 23, 2007
  • Aug 23, 2007
do you mean reverse rotation as counter clockwise looking at the engine from the front
ShortThrow50
923
Pa
Aug 23, 2007
  • Aug 23, 2007
your just being paranoid. Just buy the fms waterpump for the 5.0 mustang and your straight. It tells you right in the online catalog. I dont even think they sell an explorer waterpump
C
1997 3.8l v6 timing cover mismatch *eBay guaranteed fit* haha please HELP
  • chasondragons
  • Apr 3, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 3, 2026
chasondragons
C
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain 8.8 trac lok spider gears..
  • rednotch
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 28, 2025
rednotch
D
Foxbody Misfire 5.0 Swap
  • DPORTER0729
  • May 2, 2025
Fox 5.0 Mustang Tech Jul 13, 2025
90sickfox
