Timing cover provision??
asecretfile
228
My timing cover has a provision for a mechanical fuel pump but it looks like for the arm going in to my eccentric theres a little punchout. There any way to get this out without having to pull the timing cover off?
With the right return regulator you can keep the stock pump. They even sell adapters to go from the factory fuel lines to AN fittings.
I kept reading where even with a regulator the fuel pressure is almost impossible to get right
one like this?
quoted*****
Aeromotive Billet A-1000 Carbureted Bypass Regulator for EFI to Carbs.
Meticulously machined and impeccably finished, this Aeromotive regulator allows you to convert from EFI to carburetion. Designed to work with the A-1000 fuel pump, it delivers seamless volume, adjustable from 5 to 15 psi. Requires larger return line from bottom of regulator to top of tank.
Features:
-Adjustable from 5 to 15 psi.
-Two -6 AN outlet ports & 1/8" NPT gauge port.
-One -10 AN inlet port and one -8AN return port.
-Red and black anodized coatings.
Its saying for use with an A-1000 fuel pump though :shrug:
