Timing gurus
  • Thread starter Thread starter RsStanG1987
  • Start date Start date Jul 17, 2008
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Jul 17, 2008
  • Jul 17, 2008
I believe my timing is 180 off how do i remedy this? Give it to me in lamens terms im a moron and dont understand big words.. Thanks in advance.
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Jul 17, 2008
  • Jul 17, 2008
You distributor timing??
Does the car run? If so it's not 180* off.
If it doesn't run, restab the dizzy 180* from where it is now.
RsStanG1987
569
9
79
Dupont PA
Jul 17, 2008
  • Jul 17, 2008
It diddnt run then i moved all the plug wires.. So restabing the dizzy is a must? I guess i better restab it so i can time the bastard.
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Jul 17, 2008
  • Jul 17, 2008
Well wait..did you even take the distrobutor out? If not then leave it alone.
I'm confused. What did you do??
RsStanG1987
569
9
79
Dupont PA
Jul 17, 2008
  • Jul 17, 2008
I stabbed it at what i thought was tdc based on the book. Turned out that when i tried to fire it it backfired. Well my grandfather suggested it may be 180 so i moved the plug wires forward 180 and no when i went to start it with the little bit fuel in the carb it wanted to fire. So i guess i better move the dizzy if i want to be able to time it correctly with the timing light.
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Jul 17, 2008
  • Jul 17, 2008
Set the p;ug wires back to how they should be and just restab the dizzy.
I've often done intake installs and screwed up where the dist was stabbed. If it wants to start, spin the dist until it starts to run better. You may need to restab it a tooth over if you run out of room to turn the dizzy
RsStanG1987
569
9
79
Dupont PA
Jul 17, 2008
  • Jul 17, 2008
i could probabbly just mark where it is now lift it and spin it 180 technically. How many teeth off is 180 like 5?
Aryan15
236
CA
Jul 17, 2008
  • Jul 17, 2008
It means you're on an exhaust stroke and not a compression stroke on cylinder #1.
RsStanG1987
569
9
79
Dupont PA
Jul 17, 2008
  • Jul 17, 2008
so a restab is the only way to fix this? I cant just time it how it sits now? thanks in advance.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jul 18, 2008
#10
  • Jul 18, 2008
  • #10
no need it making things a mess.
here the simplest way to do it.
pull number 1 plug. have a friend stick a finger in the spark plug hole. get in the car and bump the start(unplug coil to keep engine from starting) keep bumping it one step at a time until your friends finger gets pushed out of the hole. this means cyl one is on the compression stroke.
now grab a big socket and look down at your timing mark and balancer, you should find that the pointer should be fairly close to the 0* BTDC mark.
take your wrench and socket and turn the engine whichever direction to get the 0 on the mark. this is TDC on cyl #1's compresion stroke.
now look at your cap and plug wires. generally number one plug wire is around the 11oclock position on the cap (if your standing in front of the car)
now take your diz cap off and note where the rotor is pointing, if the car is in time, the rotor should be under the plug wire #1's terminal. if not the timing is off.
to fix this, take a 1/2" socket or dizzy wrench and take of the dizzy hold down. pull the distributor out of the hole ( dont have to pull it completely out, just enough to get the gears out of mesh)
then rotate the shaft, you will be able to spin the rotor and dizzy shaft without moving the housing itself. now your goal is to stab the dizzy and have the rotor right under the number one terminal. sort of tricky in a way, because the rotor will move clockwise slighly when you slide the dizzy in (due to the helical gears)
so put your rotor bug slightly counter clockwise of number 1, then slide the dizzy down, if your on the right tooth the rotor will move clockwise slightly and come to a stop under number one which usually is around 11oclock like i said.
note your will be able to move the dizzy housing around while its loose. so just make sure your number 1 terminal is able to cross both side of the rotor tip. this means you can advance and retard the timing. if your a tooth off you may not be able to turn the dizzy enough to time the car.
just eyeball the rotor as close as you can under the number one terminal. put your spark plug in a the car should be close enough to start fairly easy, if not, have a buddy twist the dizzy slightly while cranking and see if it starts then.
once its running, you can proceed to adjust with the light to dial in the timing perfectly.
hope this helps..
you can time the car anywhere the dizzy sits but your have to move all your plug wires around and its just a hassle.
and you can find TDC even easier if you have the passenger valve cover off, you can watch the rocker arms while rotating the engine by hand and find TDC fast.
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Jul 18, 2008
#11
  • Jul 18, 2008
  • #11
If you can spin your dist all the way around you can time it anywhere. Us EFI guys only have a limited range, so sometimes we can't time it all the way around. That's when you hear guys say they are a tooth off, so the need to restab it 1 over and retime it.
If you cas physically spin yours, then set up the plug wires on the cap how they shoud be and spin it 180*. If it fires up you can just restab the dizzy 180* from where the rotor is pointing just so your wires and vac lines aren't all tangled around
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 18, 2008
#12
  • Jul 18, 2008
  • #12
Follow Foxfan88's directions and you will be good to go. Here are some pictures of the firing order to help out...
The HO firing order is 1-3-7-2-6-5-4-8.
Non HO firing order is 1-5-4-2-6-3-7-8
RsStanG1987
569
9
79
Dupont PA
Jul 18, 2008
#13
  • Jul 18, 2008
  • #13
Well I got this pig fired up. Runs a little rough. Where do i set the timing now with the timing light? 10* or 13* let me know.
50atheart
10
#14
  • Oct 24, 2008
  • #14
I thought I was having the same 180 degree problem.
But when I pulled the number one wire completely away from the other wires it started flashing in the correct place.
Check it before you re stab.
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Oct 24, 2008
#15
  • Oct 24, 2008
  • #15
what kind of set up do you have? 10-18deg. works well depending on what all you have done..
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
Paint and Body Rotten moon roof trim
  • Teen'93stang5.0
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 15, 2026
Teen'93stang5.0
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
D
2006 GT Windshield Cowl install
  • Daddidio
  • Mar 12, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 12, 2026
Daddidio
D
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
