I've got a '93 5.0 bracket car. I will have a chance this Friday to do some testing. This is the first chance I will have to try different things in quite a while so I was considering locking down the timing to see if I can gain some ET and make the car more consistent than it already is.
Currently I run 20° initial. This has worked perfectly since I use VP Motorsport 103 fuel. What is the usual advance on a stock 5.0? If I am to run without the spout connector, what would I need to set the timing at so that it would be comparable to the factory advance? I've asked around and have heard that factory advance is anywhere from 14° to 20°. Thanks in advance!!
