Hoping someone can point me to the right directions.
'68 289, looks bone stock down to the 2100 2V autolite. No rebuild history whatsoever on the motor.
We went to review dwell, timing, plugs and such on Saturday, set the RPM @ ~7-800 to start with, attached the timing light and....it reads like we are about 30 degress retarded (ATC mark shows well right of the pointer. Clearly rotating the distributor counter clockwise further retards the engine.
THE QUESTION: Looking at the Ford book for the'68 coupe and 2V 289, it all looks as it should. The damper marks are text book. I looked a my 64.5 289 and indeed #1 (dist cap) on both distributors are roughly in the same position. I run 13 degrees initial on mine, the stock '68 wants 6 BTDC. Audibly @ idle I have enough sweep, I can tell there is too much advance or too much much retard and have it where (garage-no load) ot behaves well.
WHY aren't these marks lines up?. Distributor is not 180 out....or the advance would be pointing aft and #1 would not be aligned....
