  • SN95 4.6L Mustang Tech
timing question??
  • Thread starter Thread starter 00torchGT
  • Start date Start date Sep 19, 2004
00torchGT
34
Orange City
Sep 19, 2004
  • Sep 19, 2004
Heres the deal I have a timing adjuster and the predator, is it possible to advance the timing with both at the same time? because the predator advances by % and the timing adjuster advances by degrees, and Im not sure what % to advance I want somewhere around 16 degrees, does anyone know the percent on the predator for 16 degrees timing? thanks in advanced
C
codyGT
365
Nebraska
Sep 19, 2004
  • Sep 19, 2004
As soon as you read this remove your timing adjuster asap.
The T/A is kinda junk. The predator is much more precise and adjusts the timing and fuel curve.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Sep 19, 2004
  • Sep 19, 2004
TA is junk , stick with the predator , I would call diablo and ask one of there techs how much % would be needed to acheive 16 degrees which by the way sounds a little high to me unless you are running 100 plus octane
C
codyGT
365
Nebraska
Sep 19, 2004
  • Sep 19, 2004
One thing that people don't realize is that the predator leaves the idle/base timing alone, which is why it is better. The predator brings the timing up by RPM.
Alot of people don't know this and then it leads them to belive that the timing has not changed.
Go HoTO!
602
Mountaintop, PA
Sep 19, 2004
  • Sep 19, 2004
You can't use both!
Your diablo will come with a standard program with the timing advanced. The amount of timing advance depends on rpms that the motor is running. As rpms climb, the amount of timing is increased. Stock, the timing is set at 10. The diablo will probably max you out at 14 or 13.5 or something like that.
The adjustments that you can make are only a small fraction. By 10%, I believe they mean 10% of the difference between 10 and 14 degrees of advance. You will never be able to get the diablo to advance to 16 w/o returning it back to the factory and having a different program put on it.
The adjustments that the diablo allow you to make are soo small that it amounts to not much more than a gimmick.
If you advance your diablo by 10% and your tuner is set for 14 degrees, then your advance will now be 14.4%....that's it.
C
codyGT
365
Nebraska
Sep 19, 2004
  • Sep 19, 2004
The predator runs the timming a he!! of alot higher than 13.5. Those values only matter when using a glorified tricker like the T/A.
The base timing stays at 10 degrees like I said earlier.
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
2003-04 Mustang Cobra Brake Conversion
  • Cassiebaebae
  • Oct 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 24, 2026
Bib36`
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
I
Removing NX NOS kit?
  • ironhorsewayne
  • Jun 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 8, 2026
squeak93
