timing question
  • Thread starter Thread starter 351w fastback
  • Start date Start date Sep 20, 2004
351w fastback
91
  • Sep 20, 2004
i just checked my timing on my car because at about 3500 it starts to hesitate or kinda miss... i checked it and it said it was on 30 degrees when it was idling? i know that isnt right so what could have gone wrong for it to show that? if it really was 30 degrees it wouldnt even start would it? i know i have a small vacuum leak cuz my intake leads oil in the front but what else could it be?
thanks
351w fastback
91
  • Sep 20, 2004
anybody?
6Stang7
1,470
Livermore, CA
Sep 21, 2004
  • Sep 21, 2004
timing marker could be wrong I suppose. I remember there being a thread where some guy had an insane timing setting like yours. I forget what it turned out to be. Once you get the reading right, I check your overall advancement.
D
D.Hearne
11,730
south louisiana
Sep 21, 2004
  • Sep 21, 2004
Just because your intake leaks oil in the front doesn't mean you've got a vacuum leak too. Reset the timing back to around 8-12 degrees.
351w fastback
91
  • Sep 21, 2004
i reset my timing to 12 and then test drove it and it didnt have any power and it would stumble and backfire a little bit. so i tried moving the timing each way until it got better. when the balancer is on tdc the #1 piston is on top.
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Sep 21, 2004
  • Sep 21, 2004
Couple of quick notes, make sure she doesn't have full vacuum at idle,(may be on the wrong port)
And #1 is on the right bank as your sitting in the car. (if you were on #5 you'd be 30 degrees off.)
351w fastback
91
  • Sep 21, 2004
Yeah we checked the right side. could the distributor be a tooth off?
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Sep 21, 2004
  • Sep 21, 2004
it doesn't matter what tooth the distributor is on if you can adjust the timing to the correct #. The only time you'd have to skip a tooth is if you couldn't turn the distributor enough to get your setting correct.
O
Ozsum2
695
  • Sep 21, 2004
Sounds like the pointer is off. Just set it (without a timing light) (my preferred method) to where it runs and starts the best.
351w fastback
91
#10
  • Sep 21, 2004
  • #10
what else could it be? valve timing? anything else?
Max Power
1,774
St Paul
Sep 21, 2004
#11
  • Sep 21, 2004
  • #11
Maybe the chain hopped a tooth and the ignition timing is making up for it?
351w fastback
91
#12
  • Sep 21, 2004
  • #12
well i set my timing at 14 degrees and hooked up a vacuum gauge and it bounces really fast between about 13 and 7 and when i increase the rpms it goes up to the normal reading. could this be a vacuum leak?
6Stang7
1,470
Livermore, CA
Sep 21, 2004
#13
  • Sep 21, 2004
  • #13
Well, what kind of cam do you have? High valve overlap cams have erratic vacuum at idle. What kind of carb do you have?
351w fastback
91
#14
  • Sep 22, 2004
  • #14
i have a 750 holley and a comp cams xe 274h.
6Stang7
1,470
Livermore, CA
Sep 22, 2004
#15
  • Sep 22, 2004
  • #15
Ok, cause I know of edelbrocks, they have two vacuum ports, and one has vacuum at idle and the other doesn't You want your vacuum advance to be in the port with no idle, so if you had it in the other, you'd have a righter timing reading. Does anyone know if holleys are like this?
D
D.Hearne
11,730
south louisiana
Sep 22, 2004
#16
  • Sep 22, 2004
  • #16
On a Holley, the vacuum port for the distributor is the one on the side of the main metering block.
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Today at 4:43 AM
manicmechanic007
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
G
Need tuning help with 4100 Carburetor
  • Gary’s 67
  • Aug 18, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 22, 2026
manicmechanic007
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
