  • 1994 - 1995 Specific Tech
timing question
  • Thread starter Thread starter legalize420
  • Start date Start date Jul 30, 2005
legalize420
1,541
South Florida
Jul 30, 2005
  • Jul 30, 2005
i am not sure how but i think my timing marker pointer thing whatever you call it is gone. is that the only place you can shine the light. after doing my intake swap i brought it to the mechanic to set the timing because 1, i did not have a timing light, 2, the car was way down on power so i knew the timing was off, 3, i am trying to learn how to use the timing i just bought. is there any place else to shine the light?
WhiteDevil
2,717
San Diego
Jul 30, 2005
  • Jul 30, 2005
Try pointing it from just to the left of your upper radiator hose down toward the balancer. YOu might have to pull the hose over just a little. You will find it.
legalize420
1,541
South Florida
Jul 30, 2005
  • Jul 30, 2005
i will go look again but i dont think the pointer thing is there. are you saying to move the hose to see if the pointer is there? i was even under the car before and did not see it. can you just shine the light on the balancer?
legalize420
1,541
South Florida
Jul 30, 2005
  • Jul 30, 2005
i found it , thanks
legalize420
1,541
South Florida
Jul 30, 2005
  • Jul 30, 2005
i just wanted to make sure...with the advance timing light you put the whiteout mark on the zero right?
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
T
Progress Thread 2002 Mustang 3.8L CV
  • TheIncompetentMechanic
  • May 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
T
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
J
Transmission
  • Jraesims
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
JD1964
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
