  • 1994 - 1995 Specific Tech
Timing Question
  • Thread starter Thread starter DarkProphet
  • Start date Start date Aug 21, 2005
DarkProphet
391
Quakertown, PA
Aug 21, 2005
  • Aug 21, 2005
Im new to setting timing. After doing the intake swap, headers, TB, MAF and injectors i had to reset the timing because i took the distributor out. What should i set it to for now? (its going up to get dyno tuned on wed morning, so it just has to be ok for now). Also, before i go get the dyno tune, should i try setting my idle without the IAC, and adjusting my TPS voltage, or will they do that?
DarkProphet
391
Quakertown, PA
Aug 22, 2005
  • Aug 22, 2005
On the balancer there are marks that go like:
10 0 10 20 30
(looking down from the top)
If i want to set it to 10* i would use the 10 to the RIGHT of the zero right?
CManT1914
3,172
Killeen, Texas
Aug 22, 2005
  • Aug 22, 2005
Set it to 10* BTDC, that is stock and works great for pretty much everybody (N/A anyways). The dyno tune guys should be able to set your idle and all that, but they might charge for it.
DarkProphet
391
Quakertown, PA
Aug 22, 2005
  • Aug 22, 2005
I just need to know which 10* to use. There is a 10* to the left and right. On the left of it, it stops at 10, on the right it goes to atlest 20.
OR the timing gun has degrees of advance on it. If i set it to 10* and set it so that im seeing 0 on the harmonic balancer would that be 10* BTDC? Like i said im new to this and have never done it before.
CManT1914
3,172
Killeen, Texas
Aug 22, 2005
  • Aug 22, 2005
I think it's the one to the right of 0. It should say BTDC or something like that on it.
Don't even use the advance on the timing gun, just leave it at 0. I have that on mine and I never use it.
Hef5.0weisen
20+ Year Stangneter
Mar 5, 2004
574
NorthWest Florida
Aug 22, 2005
  • Aug 22, 2005
from the front of the car looking down at the balancer, the 10 you want is to the right of the zero. i actually crawl underneath and mark the hatch mark with masking tape, makes it real easy to see when setting it. goodluck
DarkProphet
391
Quakertown, PA
Aug 22, 2005
  • Aug 22, 2005
Thanks, i marked it with soap stone, worked real well. Thanks again guys!
HISSIN50
34
129
Aug 22, 2005
  • Aug 22, 2005
I would set timing at 10* (stock) and let the tuner manipulate the timing tables from that.
Good luck.
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
Pro-M 75MM Bullet Flow Sheet - Is this calibrated for 36 # injectors?
  • dan50
  • Jan 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jan 11, 2026
dan50
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
