Hi Folks,
First, here's the combo:
>Late Explorer 5.0
>GT40-P heads
>B303 cam
>1.7-1 ratio roller rockers
>Mallory 57 series magnetic breakerless vacuum advance distributor
>Performer RPM intake
>Autolite 4100-1.12 carburetor
>Tri-Y headers
>T5 transmission
Here's the timing story/questions:
>At 800 RPM idle, vacuum disconnected/plugged 12 deg BTDC
>Cent. advance starts at 1000-1100 RPM "all in" +24 deg at 3100-3200 RPM giving 36 deg BTDC before adding vacuum advance.
>Vacuum advance adds 12 deg giving total "all in" timing 48 deg BTDC at 3100-3200 RPM.
Engine seems to run quite well like this, but 48 deg BTDC seems like a dramatic amount of advance. No spark knock/ ping or kickback on the starter cold or hot. Vacuum for advance is from manifold source (14-15 in. at 800 RPM) as the vacuum advance operation seems erratic when connected to ported source. I followed some advice to set at 34-36 deg "all in" (initial+cent+vacuum) which gives 0 deg initial and car runs like poop. It seems like engine could even handle a bit more timing, but that seems excessive. What do you all think? I don't want to cause any damage, but I also want the engine to run at it's optimum. Any and all thoughts, comments and opinions are appreciated.
Thanks,
Gene
>Late Explorer 5.0
>GT40-P heads
>B303 cam
>Tri-Y headers
>T5 transmission
Thanks,
Gene
I'm on the right track now and all should be good. Thanks to all for the thoughts and replies.
