  • 2.3L (N/A & Turbo) Tech
Timing retards with SPOUT out...
  • Thread starter Thread starter onebad7up
  • Start date Start date May 14, 2007
onebad7up
97
Nashville
May 14, 2007
  • May 14, 2007
I have a 2.3T Ranger and I am trying to get it to run right. The timing is retarding as the RPM's go up with the SPOUt out. It will drop a 20* just revving it to 4k. What wires in the TFI could cause this?
I swapped dizzies the other day and it is still doing it.
K
kevinspann
Richmond, VA
May 14, 2007
  • May 14, 2007
It should always be set at ten degrees base timing with the SPOUT disconnected. Im sure you already knew that, but from your explanation, it sounded like with the SPOUT disconnected, the timing was more than that
onebad7up
97
Nashville
May 15, 2007
  • May 15, 2007
Yea. I have to set it at 35* base timing just to have it be at 10* when I am up in the RPM's. It drops like crazy. When the SPOUT is in, it will initially increase and then start to fall off.
bhuff30
6,037
35
129
Olathe KS
May 15, 2007
  • May 15, 2007
That's odd for sure.
One thing that comes to mind.. the distributer shaft gear or the teeth on the aux shaft. If they are worn badly, your timing can jump around a lot, as it allows play forwards and backwords.
onebad7up
97
Nashville
May 15, 2007
  • May 15, 2007
The teeth look like they are in good condition.
ozanracing
172
  • May 15, 2007
Spun balancer?
K
kevinspann
Richmond, VA
May 15, 2007
  • May 15, 2007
This sounds retarded, and not possible, but its like your SPOUT is doing the opposite of what it should....its like it has two wires that are hooked up backwards, so its doing the wrong thing.....but like i said thats retarded.
Set the base timing at 10 degrees with the spout unplugged...then plug it in. It may be pulling out timing simply because base timing is set so high
onebad7up
97
Nashville
May 16, 2007
  • May 16, 2007
I did have it at 10* before I changed it. I did continuity tests on the wires and they all checked out okay. I am thinking maybe two wires are touching somewhere in the harness.
onebad7up
97
Nashville
May 16, 2007
  • May 16, 2007
The problem is fixed.
The wire in the TFI that has power when the car starts was receiving power even after the car started. I disconnected it and now the timing is staying at 10* with the spout out.
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
CAMTWO1070
C
Electrical Multiple spark with spout in, normal when out
  • Cumstang59
  • Dec 28, 2024
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 5, 2025
Cumstang59
C
