  • SN95 4.6L Mustang Tech
Timing Variation
  • Thread starter Thread starter TripleBlk
  • Start date Start date Mar 10, 2004
T
TripleBlk
312
Cape Canaveral FL
Mar 10, 2004
  • Mar 10, 2004
I was playing with my FREE OBDII software on my $ 80 "craptop" today. Anyway , this software allows you to peek into the real-time timing, temps, air flow , etc. etc.
Wonder of wonders timing was all over the map ! Mostly dead nuts on 14 degrees, but as low as 13.56 degrees and as high as 22 degrees.
So, how exactly do these timing adjusters you guys have work ? I thought they were purely mechanical ?? How can they override the "main brain" ?? Thanks.
I
Isaac-1
824
SW Louisiana
Mar 10, 2004
  • Mar 10, 2004
The Steeda timimg adjuster only adjusts the base timing, stock base is 10 degrees. What it does is trick the computer and therefore the OBDII readout, if you have your timing adjuster set at 14 degrees, then the timing that is really happening is 4 degrees more than whatever your OBDII readout is.
Ike
T
TripleBlk
312
Cape Canaveral FL
Mar 10, 2004
  • Mar 10, 2004
Thanks for the info !
03Sleeper
464
Fordville,USA
Mar 10, 2004
  • Mar 10, 2004
What's this software you are talking about I'd like to get it?
How are you able to conect your laptop to the car??
Thanks
Andy
T
TripleBlk
312
Cape Canaveral FL
Mar 10, 2004
  • Mar 10, 2004
Thanks
Andy
I got the BR-2 OBD II diagnostics interface. Cost me about $ 76 Made in the U.S.A
You connect the interface cable to the serial port on the laptop ( I have an old ThinkPad, but any will do) The other cable plugs into your OBDII connector under the dash
The software is FREE (Linux, DOS, Windows) I run the DOS version . You can see the temps, air flow, O2 sensor readings, MAF air flow, etc. etc
Link is
http://obddiagnostics.com/index.html
03Sleeper
464
Fordville,USA
Mar 10, 2004
  • Mar 10, 2004
Link is
Cool where did you get the plug?
Thanks
T
TripleBlk
312
Cape Canaveral FL
Mar 10, 2004
  • Mar 10, 2004
Thanks
Comes with the unit...
03Sleeper
464
Fordville,USA
Mar 10, 2004
  • Mar 10, 2004
ok where did you get the unit?
T
TripleBlk
312
Cape Canaveral FL
Mar 10, 2004
  • Mar 10, 2004
From the web site I posted a couple messages ago . Ordering details , prices, etc
should be there - thry have an ordering info page...
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
T
Trouble setting timing 1990 LX 5.0 (EEC keeps readjusting timing when spout put back in to 14-16 degrees BTC)
  • taws1961
  • Jan 29, 2022
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 30, 2022
KRUISR
J
  • JRC99
  • Apr 19, 2025
JRC99
J
Foxtoberfest 2022
  • FastDriver
  • Sep 6, 2022
8K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2022
Ford Moore
F
1990 On3 Turbo Build/Review
  • BryanNux
  • Feb 18, 2019
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 21, 2019
a91what
