  • SVT Tech Forum
Timing
  • Thread starter Thread starter Cobravenom96
  • Start date Start date Jun 28, 2005
C
Cobravenom96
48
Orlando, FL
Jun 28, 2005
  • Jun 28, 2005
This has probably been asked before but I did a seach to no avail. Can the steeda timing adjuster work on any aftermarket pulley or just on steeda pullies? I know I am running a little rich, do you think it would be worth bumping the timing to get more HP and lean it out a little?
Thanks
C
Cobravenom96
48
Orlando, FL
Jun 28, 2005
  • Jun 28, 2005
What do they mean by "piggyback" style pullies. I am assuming (not steeda) pullies?
Thanks
U
Uncle Meat
Banned
Jun 13, 2002
Prattville, Alabama
Jun 28, 2005
  • Jun 28, 2005
Correct me if I read this part of your post wrong, but are you saying that advancing your timing will lean the engine out?
U.M.
C
Cobravenom96
48
Orlando, FL
Jun 29, 2005
  • Jun 29, 2005
Yes that is correct. Please correct me if Im wrong. I could get a fuel regulator to help lean it out but I also thought that timing would do the same thing. I have read that when the timing is increased....better MPG, hense less fuel being dumped into the engine. Please correct if Im wrong.
missouri_guy197
1,441
St. Louis, MO
Jun 29, 2005
  • Jun 29, 2005
Piggy back crank pulleys such as the older March pulleys and BBK pulleys do not work with the Steeda Timing Adjuster...I believe you can use it with ASP under drive pulleys though since they are a one piece crank pulley like the Steeda's are...
C
Cobravenom96
48
Orlando, FL
Jun 29, 2005
  • Jun 29, 2005
I dont have the March or BBK's so I hope it will work. I just hate to order something that may not work.
missouri_guy197
1,441
St. Louis, MO
Jun 29, 2005
  • Jun 29, 2005
what pulleys do you have? If you had to bolt your stock crank pulley to the new underdrive crank pulley then you have piggy back pulleys and the timing adjuster will not work...If your new crank pulley is balanced like the stock one is and that's the only pulley you bolted back up to your crank then the T/A should work...All it basically is, is a new crank position sensor and encoder that is adjustable and that sits off the front of your crank instead of inside the front cover...
C
Cobravenom96
48
Orlando, FL
Jun 30, 2005
  • Jun 30, 2005
I purchased the pullies from Dynamic Racing when they were here for Fun Ford Weekend. I didn't have to put the stock pulley back on. What setting is the best for this type of engine. I was thinking 10-12. Anything higher, I may run into detonation problems.
Thanks for the reply
missouri_guy197
1,441
St. Louis, MO
Jun 30, 2005
  • Jun 30, 2005
10* is stock most people run 12-14*
C
Cobravenom96
48
Orlando, FL
Jun 30, 2005
#10
  • Jun 30, 2005
  • #10
In your opinion, do you think its worth it only to increase it by a few degrees. I didnt know they came stock at 10.
Holley High-ram tuning settings
  • spencergt66
  • Apr 1, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jun 19, 2026
spencergt66
Help. 1968 engine swap to 95 5.0
  • superdog68
  • Jun 23, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jun 23, 2025
Mcmahst
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
Tips for WUE and ASE tuning
  • Mustang5L5
  • Oct 9, 2025
Digital Self-tuning Forum Oct 10, 2025
gkomo
  • SVT Tech Forum
