Timing ?
  • Thread starter Thread starter MY 85 GT
  • Start date Start date Mar 12, 2008
MY 85 GT
1,852
208
104
New Jersey
Mar 12, 2008
  • Mar 12, 2008
Ok yesterday i installed my new fuel pump im still having the same problem it sumbles at all speeds and in every gear? I have an edelbrock 1406 600 cfm carb and i went as far as checking the cap and rotor and they were bad i need to do plug wires and im installing a new coil too......Ok i checked the vacumm advance its was hooked up wrong it was to a constant port i thought it should be to a ported vac switch so when you give it gas it will then advance the timing?? Ok i checked timing with the vac advance disconected and on my timing tab there is a metal tab with a circle and a pointer there about 3 inches apart anyways the timing mark was at the pointer is that correct or is the timing way off??? Oh yeah on an edelbrock carb what is the max fuel presure you can run? my pump is rated for 6 psi and 120 gallons per hr....i hope i can find this stumble..miss what every it is...because its VERY ANNOYING you get drive the car comfortable at all....you have to be on the gas all the time to not make this stumble....HELP....
bloopbloob
578
Alberta
Mar 12, 2008
  • Mar 12, 2008
start by dumping your codes
Fast63
717
  • Mar 12, 2008
He's running a carb.....
Your timing should be at 10 degrees BTDC to start with, and it should be at the pointer, not the circle.
You can't run more than 6psi of fuel pressure on an edelbrock. 5 psi is a safer bet. Do you have any idea what jets and rods are in it? How many turns out are the idle mixture screws? Did you install a fuel filter? Have you checked if it's plugged? Have you ever taken the top half of the carb off? is the carb brand new?
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
A
Resolved 302 still running after turning off ignition
  • AlexM556
  • Saturday at 4:37 PM
Classic Mustang Specific Tech Sunday at 5:17 PM
AlexM556
A
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
C
Bored with my 73
  • Curtis Harper
  • Apr 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 23, 2026
RaggedGT
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
