Timing
  • Thread starter Thread starter shewitt
  • Start date Start date Mar 18, 2008
shewitt
85
Newnan GA
Mar 18, 2008
  • Mar 18, 2008
If I turn the distributor counter clockwise does that make the timing go from btdc to atdc. Also when I do turn it to atdc the rpm goes up is that right.
bloopbloob
578
Alberta
Mar 18, 2008
  • Mar 18, 2008
hunh?
shewitt
85
Newnan GA
Mar 18, 2008
  • Mar 18, 2008
Sorry Before top dead center other after top dead center, Should the rpm's go up when you go from btdc to atdc
bloopbloob
578
Alberta
Mar 18, 2008
  • Mar 18, 2008
i know what the letters mean... but what are you trying to do exactly? do you not have a timing light?????
P
PJC Racing
199
  • Mar 18, 2008
Yes, when you "advance" (key word) the timing the rpm can increase. Hope your doing this with a timing light. And when your done you will need to reset your base idle and TPS.
shewitt
85
Newnan GA
Mar 18, 2008
  • Mar 18, 2008
Yes im doing it with a light I have been trying to get my idle down lower. So im going over everything tps idle screw FP. When I first started it was at about 900 then I get it set at 650 to 700 but when I plug the IAC back in it goes back up.
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
D
Engine Checking valve events with degree wheel.
  • dragstart
  • Jun 1, 2024
Fox 5.0 Mustang Tech Jun 1, 2024
dragstart
D
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
J
MSD Digital 6AL rev limiter setting
  • Jarhead67
  • Apr 12, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Apr 12, 2025
Jarhead67
J
