Tips for changing front driver brake hose.
  • Thread starter Thread starter stangzroastrice
  • Start date Start date Dec 2, 2004
stangzroastrice
278
Belmar, NJ (Jersey Shore)
Dec 2, 2004
  • Dec 2, 2004
Hey i finished the entire suspension in my car and was going to replace and hook the new brake hose up for the front driver caliper but when i try to get the brake line off (i was using a flare wrench especially made for lines like these since they are very gentle and can be easily stripped), the passenger line was fine but the driver side line will not come out, I turned with enough force to start stripping the nut so I stopped. Any tips of safely disconnecting this brake line without stripping the thing to death and having a **** load of more problems.
let me know if there is alternative ways in order to get this off (for example, disconnecting the brake hose itself rather than the line from the hose but the nut for the hose doesn't seem to budge at all either.)
thanks!
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Dec 2, 2004
  • Dec 2, 2004
Try some penetrating oil like PB Blast, let it soak in for a while. Then try some heat. If this does not work, you might have to make new fittings after breaking the older ones..
stangzroastrice
278
Dec 2, 2004
  • Dec 2, 2004
ok just to make sure i am going the right way, im pushing the wrench towards the passenger side in order to get this loose right?
90mustangGT
2,773
17
89
Dallas, GA
Dec 2, 2004
  • Dec 2, 2004
Yes, the brake lines are standard right hand threads, meaning right tight, left loose.
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Dec 3, 2004
  • Dec 3, 2004
...and resist the urge to use anything other than a good flare wrench. You'll pay for it later otherwise!
hllon4whls
BANNED
2,567
Covington
Dec 3, 2004
  • Dec 3, 2004
I find that cleaning the threads with a wire brush and using the penetrating oil helps. I had to cut mine off and put a new connector on. I did not follow my own advice and then it was too late.
Brakes Sealant for passenger side brake line fitting? (Weatherhead 7828)
  • dan50
  • Nov 9, 2025
Fox 5.0 Mustang Tech Nov 12, 2025
dan50
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Brakes Front brakes sticking - 1988 5.0
  • 302Blue
  • Oct 18, 2024
Fox 5.0 Mustang Tech Oct 19, 2024
ustacould
