tire pressure
Check your door tag. It has the reccomended tire size and pressure for your vehicle. If you are running a different size tire and or rim, contact the BFG for reccomended pressure. That's what they told me when I contacted them.
check the side of the tire for recommended PSI
That's the MAX pressure.
The recommended pressure is usually written in the door jamb of the vehicle. On my '03 GT, there's a sticker inside the gas door as well.
Tire pressure is a function of the weight of the vehicle and the size of the tire's footprint.
Stock pressure is 30psi with 245's, so wider tires can run a few psi lower with a wider surface area on the ground
