tire rating question
DerekStangGT
My package is in the mail!
Feb 18, 2003
1,068
heres a tire's specs
Specifications:
Treadwear: 280
Traction: A
Temperature: A
Speed Rating: ZR
in the treadwear catagory, is it the higher number lasts longer, or a lower number lasts longer? also, if someone could clarify the best and worst possible traction ratings, and what the temp rating means. thanks
Higher number lasts longer. You can probably easily find the other stuff out with a quick google. Also, I think tires.com and tirerack.com have FAQs about this.
280 is pretty low... Those tires will wear out QUICK
Uniform Tire Quality Grading System
The US Government has established the UTQGS, the Uniform Tire Quality Grading System, to assist consumers in their purchase of tires. Basically it's another tool to be used besides the opinions you gather from trusted friends, mechanics and whatever other sources you may have at your disposal. The key to using this system is to understand that it is a relative comparison system. The UTQGS is not a safety rating and not a guarantee that a tire will last for a prescribed number of miles. Under UTQGS, tires are graded by manufacturers in three areas: treadwear, traction and temperature. The information is right where you need it when buying the tire 1.) on the paper label affixed to the tread and 2.) on the tire molded into the sidewall.
Treadwear
The treadwear grade is a comparative rating based on the wear of a tire when tested carefully under controlled conditions. For example, a tire graded 400 should have its useful tread last twice as long as a tire graded 200. Another tire manufacturer, however, may grade a comparable design 300, so a grade of 150 would last half as long under their grading scheme. The lesson learned is to not use one manufacturer's grade versus the other, but instead to compare tire grades within a given brand. Actual treadwear performance can vary tremendously according to the tire's real-world use: variations in driving habits, service practices (most importantly air pressure maintenance) and road conditions and climate affect tire life.
Traction
Traction grades represent the tire's ability to stop on wet pavement as measured under controlled conditions on asphalt and concrete test services. As of 1997, the traction grades from highest to lowest are "AA", "A", "B" and "C". A tire graded "AA" may have relatively better traction performance than a tire graded lower, based on straight-ahead braking tests. The grades do not take into consideration the cornering or turning performance of a tire.
Temperature Resistance
Temperature grades represent a tire's resistance to heat and its ability to dissipate heat when tested under controlled laboratory test conditions. The grades from highest to lowest are "A", "B" and "C". The grade "C" corresponds to the minimum performance required by federal safety standard. Thus the "A" tire is the coolest running, and even though the "C" tire runs hotter it does not mean it is unsafe. The temperature grade is established for a tire that is properly inflated and not overloaded.
those are the specs of my current tires. after one year and 16k miles, they are about a month away from balding
Treadwear
Traction
thanks for the info!!
im looking at a 275/35/18 size for my new wheels, what tire would you recommend for mainly longevity and a little performance?
Tires
I had toyo proxes and they sucked i now have perilli p nero zero and they have a tread rating of 400. They are Nice the toyos lasted about 7 months- i do 3000 miles a month and also the toyo's were unpredicatable. They would spin open then the next they would catch really quick. The best are bridgestone postenza's s-03 pole position great great tires. :hail2:
