BlackVert said:1. Good tires - I have them. They don't make the T1-Ss anymore, at least I couldn't get them. They are now T1-Rs, and they were actually less expensive than the T1-Ss were.
2. Stock is 17x8 with 245/45s. That works out to a diameter of 25.6811 inches (785.33 revs per mile). With 9s, you can go up to 285 in the back and 255 in the front (that is what I have). If I had 17x9s, I'd do 285/40s if I could get them. That would keep the diameter close at 25.9764 inches (776.40 revs per mile). Your speedo and odometer might be a little off, but not far enough to matter.
No snow: wider = more traction.
Snow: wider = less traction.
Also, in general, the thicker the sidewall, the more traction, but the more flex when cornering.
When I get new tires for the back, I am getting 285/40s ...
i think 285 is too wide for front tires. imo, it would not look rightzZsKyZz said:Well, I'd like to keep a tire that is the same size all round. I think it'd be the best idea for handling, but I also want a tire that will have good traction and launch well during the summer. So you think a 285/40/17 would do well or should I go for a 45 if possible?
40 series are fine. I run 275/40/17's all around.zZsKyZz said:Well, I'd like to keep a tire that is the same size all round. I think it'd be the best idea for handling, but I also want a tire that will have good traction and launch well during the summer. So you think a 285/40/17 would do well or should I go for a 45 if possible?
i've been running 285 out back for 2 1/2 years now. they are still going strong.zZsKyZz said:Is there a plus to running 285's out back? More traction, right? Would they fit correctly? What are the downfalls to running that big of a tire?
i have had 285s for 2+ years now, no problemsmricci said:i thought 275 was the widest you should go on a 9" rim? If i had known you could put 285s i would have gotten them when i got my new tires a month ago. I have 275 in the rear and 245 up front but will be putting 255 in the front this summer.
