  • SN95 4.6L Mustang Tech
Tire ware
  • Thread starter Thread starter harry1587
  • Start date Start date May 29, 2005
H
harry1587
35
  • May 29, 2005
Hey, I have 03 GT mustang. I am about to lower my mustang but I have noticed a lot of tire ware on the outside edges of my tires. They are in the rear but just got rotated recently. I dont drive my car real hard so I dont see why it would be so bad. Anybody else have tire ware on the outside. Would an alignment take care of this?
YardSpecial
2,664
MT
May 29, 2005
  • May 29, 2005
YES
I drive my vert like its stolen, even tread wear on the fronts..........
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
May 29, 2005
  • May 29, 2005
actually it wouldnt. you cant adjust the caster or camber on mustangs unless you get plates. you need to buy a set of camber plates(i highly suggest the maximum motorsports ones).
EDIT: there are minor camber adjustments, but to make a real difference you would need the plates.
G
green_fow_six
310
Martinez, CA
May 30, 2005
  • May 30, 2005
If it's on the outside and inside edges, it is most likely an underinflated tire. If it is outside only, your toe in is probably off. Yes an alignment should cure that if that is the case. If you lower your car over 1.5 inches you may need CC plates to adjust the proper camber. It will be too negative causing inside wear.
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
May 30, 2005
  • May 30, 2005
get an alignment
1988_Mustang_GT
36
Newfoundland
Jun 19, 2005
  • Jun 19, 2005
I am having the same problem on my 1988 Mustang GT with 5 lug conversion. Only the front tires are wearing, and only on the outside edges. I had an alignment done after 3000 kms, but the problem is still there. My car is much higher in the front than in the rear (something to do with the suspension setup I guess). I'm not sure if that is what is causing my problem. Maybe the alignment set the toe in correctly, but the tires are probably still wearing due to the damage that was already done. What do you think?
Resolved 2015 ecoboost pp bumpsteer issue
  • matthewt
  • Aug 1, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Aug 3, 2026
fasterthangas
F
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
R
Wow, Tire Issue on 2019
  • Rcdgl
  • Dec 30, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 11, 2026
Rcdgl
R
