I don't think you can lower the engine enough to get it right. I put a tko 600 in my 67 GT with FE. I really did not want to cut the tunnel and tried not to but I could only get the angle to 6 degrees with the darkhorse cross member, any closer and it would hit. The correct angle should be about 3. If you need to see a difference just cut a 2x4 to the length of the engine and tranny and set it at 6 degrees. I thought it really looked stupid setting in there like that.
My hooker headers hit the steering box and idler arm. They also set about 2 inches lower at the collector. I don't think I could have ever got the correct pinion angle to prevent wheel hop. So I made the decision to cut the tunnel and fab my own cross member.
I can send you some photos if you like. John
