I'll probably be needing a new tranny this summer, so I need to decide between the G-Force T-5 or a TKO.
G-Force
-True Bolt-in synchronized replacement gearsets capable of handling up to 600 streetable horsepower -$1000
-Overdrive gear set (.90 when available) -$360 -Don't know if this is neccesary?
Upgraded Mainshafts
-ASTM 9310 High Nickel Steel -$295
OR
-ASTM 4340-300M Thru Hard Premium Alloy -$495 -Any suggestions?
-Spec Stage II -$289
-Spec Aluminum Fly -$359
-T-5 Rebuild kit -??? (Any ideas)
Plus installation ~$250 -Just for the T-5 parts
TOTAL ~ $2,553 OR $2,753 depending on mainshaft choice, prices exclude the T-5 Rebuild kit
TKO
-TKO Tranny -$1,375
-SFI Approved Bellhousing -$299
-TKO Shifter -$190
-Spec Stage II -$289*
-Spec Aluminum Fly -$359*
*Are these the same weather it's a T-5 or TKO
-Driveshaft Yoke for the TKO -??? Any Ideas
-Modify crossmember - ??? Any Ideas
TOTAL ~ $2,512 DEPENDING ON DS YOKE AND CROSSMEMBER MODIFICATION
-AM I MISSING ANYTING WITH EITHER THE G-FORCE OR TKO SWAP???
Thank you very much to anyone that finds time to reply!!!!
Jake
G-Force
Upgraded Mainshafts
OR
TKO
-TKO Tranny -$1,375
-TKO Shifter -$190
Jake
