TKO or T45?
  • Thread starter Thread starter PhilJustPhil
  • Start date Start date Nov 9, 2011
P
PhilJustPhil
36
Ottawa
Nov 9, 2011
  • Nov 9, 2011
Keisler Engineering is now offering a "Perfect Fit" T45 5-spd kit in addition to their TKO kit. The TKO is priced at about $500 more ... is the TKO worth the price premium? (Why?)
Keisler has given me quotes on both systems, but hasn't said which one they would recommend.
Going into a '68 with the 390 GT FE and a few bolt-on's.
Thx!
Phil
65coupe408w
192
  • Nov 10, 2011
if you are going to be putting any power through the drivetrain I would suggest the TKO. The T-45's just arent that good. I would take a T-5 over a T-45 any day. Just my 2 cents.
SitDown
335
Chicagoland
Nov 10, 2011
  • Nov 10, 2011
Thanks for bringing these guys to light, didn't even know of a slim case TKO. What was their quote for the slim TKO?
If the car is just a cruiser, a std t5 will be fine for you. Buying a slim version of a t5/t45 isnt necessary. As mentioned above, if you plan to put some more power through it, or expect to be launching hard at the track a TKO would be more appropriate. Also x2 on the T5 over the T45
P
PhilJustPhil
36
Ottawa
Nov 10, 2011
  • Nov 10, 2011
Not pocket change
$2694 for the T45 and $3199 for the TKO. Both rated at 500 ft lb torque.
These kits are complete down to the pilot bushing, the driveshaft (specify length), cross member, speedo cable etc etc
Phil
mtaqua
345
  • Nov 11, 2011
I'd get the 600 and have room for growth. Seems like most people (to include myself) are never fast enough or have enough power. I realize $500 is a quite a bit of money, but it'll be less than a rebuild or worse a new one when you break the T45.
65coupe408w
192
  • Nov 11, 2011
PhilJustPhil said:
Not pocket change
Phil
Seems that this isnt just a regular T-45 so in that case my point about strength doesnt really apply. For that money you may want to look into a G-Force built T-5 also.
As mentioned above, it all depends on what you want to do with the car. Good luck and let us know what you choose!
9
96 DOHC Cobra
542
Cerritos, CA
Nov 11, 2011
  • Nov 11, 2011
I have a T45 in my 96 Cobra and hate it. I wouldn't put a T45 in anything I want to drive. I thik when my car hits 45-50K miles, if the T45 is still alive, I'll swap it out for a T56. There's no way I would put a T45 OR a T5, even built units, behind an FE motor.
mtaqua
345
  • Nov 11, 2011
Also, if you go the T-5 route, astro performance makes a A-5. Upgrades to 550 ftlbs and 675hp. I am running one, I a haven't really ran it to much yet for feedback. It does shift well. Customer service is great.
Sicarius428
2,085
Nov 15, 2011
  • Nov 15, 2011
TKO is a stouter platform. I would go with a TKO600 but I am bias. I was in a similar boat when my t5(similar to the T45 without the funky bellhousing) gave out on my 300HP 5.0. TKO will handle the torque you have and then some.
Kevin
9
93CoyoteCoupe
14
Oklahoma
Nov 21, 2011
#10
  • Nov 21, 2011
  • #10
T45 to T56 Conversion
I already have a t45 in my Fox.
How hard would it be to install a t56?
What would have to be changed?
P
PhilJustPhil
36
Ottawa
Nov 23, 2011
#11
  • Nov 23, 2011
  • #11
In speaking with them, strength really doesn't seem to be a concern - their T45RS500 is rated for 500 ft lb continuous. My mild 390 won't be making that. The salesguy also offers his opinion that of the two choices the T45 is smoother shifting. So I pulled the trigger and ordered it today (3 month wait).
Seems the kit isn't as complete as I thought - had to also order a clutch (due to input shaft spline count mismatch, couldn't use my current clutch) and a shifter handle.
chris66dad
167
Benicia California
Nov 23, 2011
#12
  • Nov 23, 2011
  • #12
A5 looks like a good bet for high HP
Pro-Force built - Astro A-5 T5 - 485 ft/lbs - 550 hp - $2000.00 plus your rebuildable T5 core
These are available with either the FOX input shaft, or the SN95 length shaft.
All of our A-5s include the billet countergear support plate and all new Timken brand bearings.
Fifth gear will be 0.64 unless otherwise specified.
Upgrades to the A-5:
- Billet synchro keys for third and fourth gear - add $50.00
- 575 ft/lb - 650 hp upgrade using the 9310 Alloy mainshaft - add $400.00
Astro A-5 Transmissions in Atlanta
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
M
  • mnky99
  • Sep 5, 2025
mnky99
M
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
