Is it worth it to put a hotter cam ina stock 302, stock heads. The only mods are RPM Air Gap intake, headers, dual exhaust. If so, what is the most you would go. Is a "268" cam too much?
I disagree. The seat of the pants feel will me more than 10hp. I did this many times back in the days before aftermarket heads, and a decent cam always made a pretty good difference. It will not be a screamer, but you will definitely notoce a difference.
.Stock E7 heads flow like crap, that can't be disputed since the numbers don't lie. Opening up the heads and mill'n them to achieve more CR will do more than a cam swap alone; which is the point I was making. Try as you may, but a bottle neck will always be a bottle neck until you address it; stock E7's quite flowing at .400, they DECREASE flow at .500. Port them correctly and you can get flow up to .600 easily. I agree w/youy tho, a difference will be noticed, but the butt can't determine the difference betwen 10hp and 15 hp; so how did you determine what your actual hp gain was? Ed Curtis, who grinds cams for NMRA racers, will also tell you the same thing about the E7's and aftermarket cams. I'm SURE he knows what he's talking about. My view, as Dave pointed out, if you're doing the work and spending the money for a cam swap, you might as well touch the heads since one has to come off anyway.
Since I would have to remove the heads to check p/v/ clearance, I could easily open and smooth the exhaust ports. It sounds like most think it would be worthwhile. It may be years before I can afford a stroked, aluminum headed monster so I am just looking for a little more fun on a no-dollar budget.
I e-mailed Comp Cams for a recommendation but haven't heard back. They will probably suggest a lesser cam from what I have heard of them (err on the side of caution to prevent unhappy customers).
When did he say he was using E7TE heads? This is in the classic tech section, so I'm assuming by 302 he's referring to an early 302 and not a late model roller 302. Unless you happen to know that he is running E7TE heads, than all of your talk about the E7TE heads isn't specifically t relevant to him.
