to change the steering wheel
depends on the certain one but in your case, factory wise, you pull the center pad off and there should be just a bolt.. you'll have to jerk on the steering wheel back and forth to get the wheel itself off but it can be done in like 5 mins.. lol
Some steering wheels are a real bear to get off, I personally never delt with one that came off easy. I would totally recommend that you get a puller to remove the wheel. I'm not sure if they have those as part of the tool loaner program at the parts stores. Good luck. If your getting a Grant your probably going to need the adapter kit, grant makes that too.
