to install or not...
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
the hood is going on my car for sure... the lower valance is up in the air right now
For what a street car? Or race car? For the street I wouldnt, I'd go with something like a saleen. But for racing you dont want to mess up all those aerodynamisies.
thats actually modeled off the saleen lower... it just solid and doesnt have have the holes. it would be on my car... which i do drive on the street but its honestly to the point its pretty much a race car
Yea I can tell it looks like a saleen air damn just filled, but it looks a million times better with the holes. But if it's pretty much a race car I'd use it, it doesnt look bad, it actually looks cool, definitely something most people arent going to have, but it definitely looks race purpose so I guess it depends what look you're going for.
I think something else that matters is what side skirts and rear you are going to be running. LX? Cobra style? GT?
Put it on. I have the width of your hand in clearance, between the bottom of my air dam and the street surface. 90% street driven. The only regular hazards are parking curbs. Here's a tip.... don't hit them. :P
haha its actually not much lower then the stock LX bumper. its just made to push air around the car and not into the engine bay to make a big air pocket. we picked up .1 and about 2-3mph putting it on the coupe
Same one i have on my car. I think its the only acceptable nose to put on a coupe besides the factory LX one. You are going to need a big air deflector for street driving.
i dont do much street driving these days... not that its unstreetable its i just dont have time to take it out much any more
Can't say I care for it. I bias though, since I like the stock LX front clip. Have you wondered what kind of issue you might have with cooling on your daily? That piece looks like it would obsrtuct a lot of airflow coming through the rad and hold in even more heat? OK on a race car with upgraded cooling, only making 1/4-mile passes at a time. Not so much for the guys stuck in stop and go traffic on the interstate, with limited airflow. :shrug:
In actual real world, I've discovered that the reverse is true. Cutting air from beneath the car INCREASES pressure at the bottom of the air-dam and creates more reduces pressure behind the radiator.
I added my air-dam to increase front end stability at high speed... It was an added benefit that I got more cooling efficiency as a result. No other changes were made to the cooling system at the time so it was a discovery (for me). Later, I replaced my 160* t-stat with a 180* because of the amount of time it was taking to get the cooling system up to operating temp. All along, I was just not getting enough air through the radiator at highway speeds.
Edit:
Oh... and I think it looks great with LX trim. :nice:
Me too, ive seen them on GT's and they actually look goofy to me.
pic.php
pic.php
I wish i had a good pic of the air deflector. Its off of the old boxy rangers and broncos, the thing is huge, but it works awesome. No cooling issues whatsoever. Stock standard rotation WP, and a FMS aluminum radiator with taurus fans.
Reactions: SteedaGT9150
daily??? ive put MAYBE 3000 miles on the car in 4 years
If you're gonna drive it anywhere other than the track for any length of time...then it doesn't matter if you put 1-mile on it. It's still gonna be subject to the same conditions.
In any case, you seemed determined to do it regardless of what's said here, so why are you wasteing time talking about it on the internet? Go start turning wrenches. :shrug:
Edit:
Now...did you completely block off the factory LX front facia below the bumper trim, or just add a dam to the lower half of the existing set up? Or did you go with an aftermarket front clip with a lower stance to the original? Got any front end pics?
...because we had the exact effect I was describing when whe put a similar front dam on my brothers '87 LX. Heat levels rose in both engine and transmission (AOD car). To the point where he had to relocate his transmission cooler for better airflow. I've even found that even removing the rubber trim piece along the bottom has a negative effect on airflow? :shrug:
im stuck at work... and i couldnt put it on my car right now if i had it in my garage anyway. i need to redo the glass work on the sides where we had the exhaust ran. and i need to get my car up on jackstands so i can fit it to my car.
pic.php
I changed my mind, that looks AWESOME.
