To keep or not to keep.
mustangt562
226
Long Beach
I just finished removing my A/C and the only thing I was not able to get to was the condenser. Is there a benifit to removing the condenser? Will removing the condenser make that much defference in cooling the radiator? How much does the condensor weigh? If anyone removed their A/C and opted to keep/remove the condensor please post your reasoning as to why you decided either way. Thank you fellas. :)
just remove the radiator, which should take all of 10 minutes, then remove the condenser. i removed mine when i ditched my a/c, now my fluidyne is fully exposed to airflow.
first I need to tell you that your engine bay makes me jealous :nice: :hail2:
can you give me any tips on how to get to the condenser? how do i get the radiator out?
BTW is that a stock hood with that rpm 2 under it? did you have to do any modifications to get it to fit?
no, its a cobra r hood from cervini. i dont think the rpm II will fit under the stock hood. u might be able to move the rad forward enough without having to actually drain the coolant and remove it. i deleted my a/c at the same time i did the radiator so it was all apart. u need to take off the headlight panel cover and disconnect the lines at the condenser if u haven't already. then its just a matter of unbolting the mounts for the condenser and radiator, try to move the radiator forward enouugh to snake the condenser out.
