To people using the flaming river rack........
I am thinking of getting the flaming river kit for my coupe project and I was wondering is it really worth it? I know it will lighten up the front end a bit and also make it neater under the hood not having the power steering pump and lines. How good do the racks work? Are they easy to turn the wheels with stock size tires or just when you use skinnies. See, I'm going to use my 17x9 cobra r's for the weekends and when I run it at the track I've got a set of welds. So, I guess I need to know if I'll be okay with the manual setup with big tires up front?
thanks,
Matt
I have the Flaming River kit on my car and I don't mind it at all. What I like about it is making things simpler, less components, no more pump whine, no more drag on the belt, and cleaned up the engine bay. I have 3.5" Welds up front, which helps turning I know.
At a dead stop: have to use both hands and use some muscle.
At a slow speed: still have to use both hands, but much easier
At higher speeds: feels just like power steering
I really like the feel of it. You feel more through the wheel than with power (more precise)and once you've made a turn you can just let go of the wheel and it will snap right back straight... no need to turn the wheel to straighten up.
A friend of mine just got it too and he has 2000 GT wheels (17"x9" I believe) and he described it as being pretty much like mine. I haven't driven it, but he described the same things I just did. The only time you'll be grunting and groaning is at a dead stop. The main thing is... Flaming River manual steering IS alot easier to stear than a power rack with the pump removed and the lines capped off. Or like if you have power steering and you try to turn the wheel while the car is off.... manual steering is ALOT easier to turn than that.
But the only car I've actually driven with manual steering is mine with the 3.5" fronts, so maybe someone who's driven it with bigger wheels will chime in.
Hope this helps!
Thanks for the info Badponysc. I know a few people who have the racks on their cars, but they are the kind of people that are so biggity, even if it sucked, they would tell me it was the greatest thing in the world........ You know the type........ But thanks again for the rundown on the rack because I am highly considering it as my next mod. Any more people wanna add their opinions because I highly welcome them...........
Thats the rack I have, you will need a manual steering shaft or the flaming river one. If you are in no hurry, I have a factory one, but with my 351w I think its gonna hit my headers. I will be getting a flaming river shaft soon.
I'm really happy with it. High quality stuff but you pay for it. They're not cheap. Stick with the standard rack they sell instead of the quick ratio. I'd say the quick ratio is quite a bit harder to steer than the standard. As with most manual racks, it's easy to steer once you get moving. In parking lots it's not too bad if you have skinnys. Never drove mine with stock size tires.
