Tokico Illumina 5-way people come on in!
Fast02
239
I'm picking up a set of these in the morning. Right now I have the stock shocks/ struts with Eibach sportlines..man the ride is crazy harsh right now. What settings do you guys run? How much better will the ride be?
I love the ride of my 5-ways. I keep them on 5 in the front and 4 in the rear. If you put it on 5 in the rear then you will have your rear swinging out. 4 is perfect with my sway bars
On the Tokico Adjustables (3) is the setting that Tokico NON-adjustables run at. 1 and 2 are softer and 4 and 5 are harder. I put mine on 1 for Highway trips (good smooth ride) and put the fronts on 5 and the rears on 4 for when I run "The Tail of the Dragon". Normally they stay on 3 all the way around.
Striped97 said:
How hard is it to change the settings, do you have to pull the wheel and stuff or what? I'm guessing thats the least you would have to do to get to the shock/strut.
no..just lift the hood and change the little dial right on top of the strut...same with the shocks in the rear...takes about 30 seconds from start to finish..
