Tokico Ilummina's or D-Spec's?
What do you guys think? Which setup do you think I should go for. I want to combine one of these setups with H&R Supersport Springs. I can get the Ilumina's for $550 and the D-Spec's for $520. Any suggestions?
That is a no brainer! Go with the D-Specs hands down. I have them with my H&R SS and the ride is great. The adjustability is also so much better than the iluminas.
If you do go w/ Illumas you can get a better price than $550 that pretty high. $425 is what prices I was finding.
My D-Specs were $525 and I purchased EVERYthing from www.stangsuspension.com GREAT customer service and fast shipping.
Make sure you have 4-bolt CC plates Steeda or MM plates would work best since you need to be able to adjust the strut hieght with the D-specs
Hard for me to say which is better because I have only had the Tokico's but I have to say that I have been really impressed with them. My car handles like it is on rails (not only because of shocks of course) but they help a lot. Setting 1 (least stiff setting) is pretty crappy IMO. Settings 3-5 are just perfect. My 2 centz.
Um they both are Tokicos???:rlaugh:
don't mind ^, he has jungle fever :D.
go with the dspec. if I'm not mistaken, it has an in-car control setup? you can change the settings via a button mounted in your car. or I might be thinking of something else.
Sorry, my brain was not working yesterday when I posted in this thread. :crazy: Anyway, I was trying to say that I have the Illuminas and like them but I think it is time for some new ones just cause they are 4 years old. I will look into the D-Specs. It has been a while since I went shock shopping. Mine have a notch on the top that you can turn to adjust firmness between (settings) 1-5.
So, what is the difference between the two? Just two more settings?
san~man said:
Will you really *adjust* them that often, and how much of an improvement would you get over a monotube like a Bilstein?
You assume just like I do about this crap, no one ever states what they really want out of their car, drag or carvin' specific. I always steer tward handling insted of dragging.
Most of them though want something to take turns on rails and pull some better times at the 1/4mi
