Too much fuel?
91phoenix
20
I have a stock block with JE racing pistons, edelbrock performer rpm heads,steeda#18 cam, cobra intake, 65mm throttle body, cold air intake, headers and full exhaust and on the advice of friends recently went with flow matched 24# injectors (ebay) and a pmas mass air (yes calibrated for 24's and cold air). The cold starts were much better and part throttle drivability a little smoother but I had high rpm backfiring and the car seemed sluggish. In 5th at 70mph it would barely accelearate and again I had backfiring. I went back to the old 19's and stock mass air and the car runs MUCH better. No more backfiring and I can feel the cam come on at around 3000 again. Are the 24's too much for my setup? Or should I be looking for another issue? Thanks Stangnet!
Always disconnect the battery negative terminal for 10 minutes anytime you change a sensor. That will force the computer to adjust it's program to match the new sensor as closely as possible.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
There is a single dark brown connector with a black/orange wire. It is the 12 volt power to the under the hood light. Do not jumper it to the computer test connector. If you do, you will damage the computer.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
