too much lift?
  • Thread starter Thread starter samuraichamploo
  • Start date Start date Jul 25, 2004
samuraichamploo
367
Beaumont, TX
Jul 25, 2004
  • Jul 25, 2004
94 roller 351w with stock pistons
F303 cam
1.72 roller rockers
Trick flow twisted wedge heads (older model, non adjust. valvetrain)
The heads have been decked 1/10,000th
If it is too much lift, If I use stock roller rockers, will I be in the clear?
maverick0716
3,924
Chilliwack, BC, Canada
Jul 25, 2004
  • Jul 25, 2004
I have no idea about a 351W but I know if it has the same valve reliefs as a 302 then it's gonna be VERY close.....it will most likely hit.
If you use stock ratio rockers (1.6) then the clearance should be fine. By the way, the stock rockers shouldn't be roller unless you meant just stock ratio.
TIMMY2734
1,330
Queens, NY
Jul 25, 2004
  • Jul 25, 2004
As Mike Yount has said countless times, peak lift has nothing to do with P/V clearance. When the valves are at peak lift, the piston is at the bottom of the bore. You encounter problems during your duration and your overlap.
Without knowing 100% about your valve reliefs, you will only get an accurate answer by claying the pistons. Do you think its worth the amount of time to clay them? I sure as hell would
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jul 25, 2004
  • Jul 25, 2004
Timmy is the man.....
salty - go here and read up on the issue. You have to measure....
http://www.diyporting.com/PVC.html
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
2K
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
