Looks like there are three wires used at the switch. The BR/LB shows 'not used'. With the ignition in 'Run' check for power at the P/O wire. If the P/O wire has power then check for power at the Purple wire in the 'raise' position and power at the GY/LB wire in the 'lower' position.
