I have heard of extra deep crank bushings as well.
They stick further out of the crank to grab the shorter nose.
This is probably a 'band aid' fix compared to swapping to the correct shaft, or better yet, getting the right tranny.
Using the short nose FE unit on a small block will work for a while, but the lack of support will ruin the front bearing and eventually the gears.
Check your numbers too and find out if that is a close or wide ratio.
Wide ratios are better on the street...
Personally, I would never use a close ratio.
