Torker II
  • Thread starter Thread starter 86bluecobra
  • Start date Start date May 24, 2006
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 24, 2006
  • May 24, 2006
Is anyone running a Torker II intake on a 351w carb'd? I found out that the vic jr requires a different msd dizzy then i have and i was wondering if anyone has run this intake or if it is even worth buying? I would like a single plane to go with my vic jr heads. i currently run a wiend stealth dual plane.
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
May 24, 2006
  • May 24, 2006
Yea I know a few that run a torque 2,nice thing with it is the fact its not as tall like the victor jr.
The three things I dont really like is that the plenum volume as cast is small (but a 1-2" open spacer will take care of that),the entery into the ports is practicly 90* (bad for having fuel drop out of the stream) and the log style runner make cylinder "cross talk" and fill less even.
But for nitrous its still a step-up
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 24, 2006
  • May 24, 2006
i was thinking bout running that intake with a 1 inch spacer. that intake and my current dual plane are for the same rpm range and basically that torkerII looks like a wiend stealth with the divider plate of the dual plane removed. It didn't look like a awesome intake design if you ask me.
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
May 24, 2006
  • May 24, 2006
Yea,the flat runners dont exactly provide an optimal entery angle....
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 24, 2006
  • May 24, 2006
what kinda cam would you go with for this intake and vic jr heads? for that matter what cam for the vic jr heads and a super victor intake?
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
May 24, 2006
  • May 24, 2006
flat tappet or roller?
you can also go solid flat tappet for reasonable price if you want to turn some more rpms (6800ish rpms),and still keep a low buck deal (we were turning 6800rpm with the hyd. roller so its good to about 7-7500rpms )
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 24, 2006
  • May 24, 2006
it will probably be either a hyd flat tappet or hyd roller
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
May 24, 2006
  • May 24, 2006
Well if you stick with hyd. flat you probably wont need new pushrods,though the roller is obiviouly better for power.The flat may have some advantage down low....
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 24, 2006
  • May 24, 2006
am i going to have to go to a cam with more lift? in order to take advantage of the heads and a single plane?
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
May 25, 2006
#10
  • May 25, 2006
  • #10
Lift is good,more is better.
Duration will mostly affect your real power span though,and lobe speration angle will effect your n/a vs. nitrous power and can also effect your power span.Also choosing the right intake valve closing is important to keep a good dynamic compression at low speeds,but not to early as to mess you up at top end.And go with the fastest lobe (ramp rate) that doesnt destroy your valve seats and valves.
Its all in balancing and what you want.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 25, 2006
#11
  • May 25, 2006
  • #11
so basically i should just give my combo to comp cams or lunati and let them pick me a cam.
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
May 25, 2006
#12
  • May 25, 2006
  • #12
Yes,lol.
They will be able to help you out as they know from experiance what cam works well with certain combos.
www.cammotion.com does our cams and they arent bad on pricing,never priced a flat tappet though,you might want to go custom if you dont find something you like.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 25, 2006
#13
  • May 25, 2006
  • #13
i was told to talk to lunati because they recruited a custom cam guy that is basically the best. he was being persued by all the cam manufactures. my buddies uncle has a custom cam shop and i have heard good things about him.
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
May 25, 2006
#14
  • May 25, 2006
  • #14
Thats cool,if hes decent then supporting good local buisnesses is nice.
Just remeber if you get just a cam,you WILL ABSOLUTLY need new lifters.
And a good break in lube (I actualy use the ARP moly lube)
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 25, 2006
#15
  • May 25, 2006
  • #15
yes i would do the proper break in procedure and i would run new lifters.
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Holley High-ram tuning settings
  • spencergt66
  • Apr 1, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jun 19, 2026
spencergt66
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
