Torque convertor stall Q's
I am about to order a new convertor from summit and i need some advice on which stall to go with in my cougar
2000 or 2400
heres my setup
1968 c4 TCI super pro rebuild wth scat valvebody
302 stock block, long tubes, edelbrock performer RPM intake with a holley 600 cfm, 3.55 rear
used for mainly street driving with the occasional trip to the track
any help would be appreciated,
E303, isn't that for a roller motor?
From your post it looks like the E303 has a 220 duration at 0.05" lift. If that's correct, then I would consider this a mild to medium cam as far as agresivness is concerned.
It depends on what you plan to do with the car, but I'd reccomend something between 2000 and 2500 rpm depending on how agressive you want to get.
I run a 2600rpm stall with a 228* @ 0.05" with mostly street driving and the odd trip to the track. It seems to be just about perfect for what I want..
I'd consult with your cam manufacturer to see what they reccomend.
