hi guys, im gonna add a new torque converter in the very near future. New flowmaster one chamber delta force mufflers just installed with box tipped side pipes, awesome frikin sound and looks killer. I'll try to get you guys some pics and clips of it. A refresher:
-302 block
-AOD w/ shift kit
-3.73's
-b303 cam
-ported and cleaned stock heads
-stock inducton and intake for now
-dynomax shorty headers
-electric fan
-Offroad H
-no a/c
-19 lb.hr injectors
-75mm MAF
-flowmaster delta force one chambers
dynoed at 303hp at the flywheel before cam swap, not too shabby
haven't dynoed it with new cam yet
The cam makes the most torque at 3300 rpms and i dont want to spend too much money, maybe around $300, I was thinkin of a B&M holeshot 2400 or B&M Torque Master 2400. Is the holeshot one worth the extra $35? Should i go higher to a 3000 or will a 2400 be fine? Its an every other day driver. Will this suck for regular street use witha 2400 stall on takeoffs, does it like just spool up like a manual then go or what? And whats the difference between lockup and non lockup? Thanks.
-302 block
-AOD w/ shift kit
-3.73's
-b303 cam
-electric fan
-Offroad H
-no a/c
-19 lb.hr injectors
-75mm MAF
