Torque specs for intake?
I see now you have AFR's. I'd back off the torque to about 15-18 ft/lbs. It doesn't take much to strip out aluminum threads with steel bolts, especially the end bolts, they don't usually have as deep a threads as the others and it doesn't require that much force to keep the intake in place.
I put teflon sealer on the end bolts as they go into water jackets. I torgue to twenty lbs in two steps, then check it again after a heat cycle. The gaskets will squish a little. I too have aluminum heads, but Edelbrock uses steel thread inserts, so I didn't bother with anti-sieze.
