Torque to me !!!
  • Thread starter Thread starter Spanish Dave
  • Start date Start date Apr 24, 2004
Spanish Dave
147
Oliva, Valencia, Spain
Apr 24, 2004
  • Apr 24, 2004
Hi all
How tight should I torque the bolts on an alloy inlet manifold fitted to a 289 with 351W heads?? My buddy says 26 ft. lb. which I tried and sheared the first bolt The *RTFM* says 14 -16 for stock 289 with iron manifold ... any advice what the correct torque should be?
BTW this is the second bolt that has broken on this car at fairly low torque (the first was on the clutch cover plate) .. are there problems with these 40 yr. old bolts? or is it just my bad luck.
Have had to send off to the USA for some replacement bolts and will miss the classic car rally which we were going to tomorrow .... Grrrr!!
KillerKittyCat
150
Hammer Down - Behind The Wheel
Apr 24, 2004
  • Apr 24, 2004
SD - 14-16 should be fine. Any "grade or class 8" bolt will work for now. However with aluminum to iron I would do the following.
Torque to 25.
Back off all bolts 2 turns.
Re-Torque to 15.
Hope this helps.
rbohm
6,698
550
204
tucson,az
Apr 25, 2004
  • Apr 25, 2004
i have always used 25ft/lbs untill i have problems with a vacuum leak, then i went to 30ft/lbs and have yet to have a problem. i also try to use new bolts when i can.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
T
Turning over fresh 347 stroker torque question
  • TexxDex
  • Apr 1, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 1, 2024
Bullitt347
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
Fox Build ideas for the 'Hudson Heap' (87 GT)
  • MadSquirrelTech
  • Sep 19, 2023
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 27, 2023
MadSquirrelTech
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
