Okay, so I disconnected the battery and started all over with the test. I think I realize what I was doing wrong. I was not tapping the gas pedal to WOT when it was doing the dynamic responce test. So, maybe the 3 digit codes that were coming out were just error messages. I am now getting code 44 during the KOER test, and this is a code that I got 8 years ago when I bought the car. I fixed this issue but the code still comes up. Anyway, thanks for the help with this.
On another note, now that i have your attention, I am having another issue with the car, and this issue has been evident ever since i bought the car, it has just gotten worse over the years. When I first bought the car, like once a year the engine would break up during WOT around 4k RPM. As I modded the car over the years (new intake manifold, air intake, mass air meter, TB, headers, full exhaust, gears) the problem has gotten worse and it happens pretty much every time I have the car at WOT. It also seems to be more evident during warmer temperatures. It usually starts to break up at around 3k. It also did it once when i put it in 5th gear and bogged it down. The engine broke up very low in the RPM's when I did this.
I was told to try maybe going to a colder spark plug, so i went 2 degrees colder from 25 to 23. I also bumped the timing to 15 degrees and am now running 93 octane. The car now breaks up a bit, still at around 3 - 4K, but not quit as bad as it did before. Any ideas on what could be causing this issue? Any help would be greatly appreciated.
