TPS help
Unplug the TPS sensor and check the body-harness wires (key on). Now you should be back to one wire showing 12 volts. Ohm out the ground wire, looking for low single digit resistance). You can check continuity between the 3 wires to be sure there is none.
Then do continuity tests between the 3 terminals on the old TPS. They probably have low resistance (continuity).
If that all hashes out, a new TPS should have you back to normal.
You guys are gonna love this one. From the engine harnes Orange wire 5v black wire has 5v also 0 on green.
TPS continuity
G/B .5
G/O 3.5
B/O3.8
Looks like the tps is good plus I swaped it with a spare I had. Testeed both of them and results were similar.
Pulled the black out from the tps and ran to a local ground. Tps dead on 5v in and .99 out.
More suggestions.
Thanks
Sorry some additional info restance on black wire into the harnes 4.3. SHORT!
I know you're concentrated on the TPS but, have you run a KOEO self test?..... any other failure codes showing? ... BP, ECT, EVP, ACT ?..... can you initiate a self test by installing a jumper between the STI and SIGRTN terminals in the VIP connector?...... LUK
I am getting codes 51 22 53 31 67 81 82 84 85. No emmision equipment on this car. No egr smog pump, canister etc.
I have been sorting throught these but could figure out how they were realated.
This started with hot start problem. Would turn over great run forever but when I shut it down no restart. Tested fuel pressure and spark at the coil and plug. All tested well. Plugs were wet which got me thinking about flooding. Tried the old peddal to the floor with no luck. Then got me thinking ECT and tps at wot not shutting off injectors.
Worth noting that when i grounded the tps localy and set the tps to .99. Car runs I let it warm up and tried a restart. Cranked on it for a minute with out starting then pedal to the floor it fired right up. I think that was the problem with the hot start but now why the tps voltage problem.
I noticed the bap, tps, ect and act use a common ground wire. Is this the case? If so could it simply be a grounding problem. That would make me happy. Im thinking it might explain the codes for the other items as well.
Well what do you know, the neutral safety swich grounds on that circuit as well code 67. HMM Im starting to think grounding problem
Ok moving on. 5v coming out of sig ret wire through salt shaker from main harness. Now I know thats not right. Shouldn't that be 0v ... guess i will just keep going.
Well 5v comming out of pin 46 on ecu. Anyone car to venture a guess. At this point Im stumped. Thought for sure I would find something by now. Any help is really appreciated.
