Got in my car the other day and started it up, shot right to about 2200rpms. Cut it off, started again, same. I can drive it around for a little while and it seems to go away, but sometimes it returns. I can disconnect my IAC and it will fall back to my base idle, about 800rpms.
I pulled KOEO codes and got a code 23, TPS. I thought my problem was going to be with the IAC, so I took it apart and cleaned it. I went back through the Idle Setting List but still came out with the same result...seems to have gotten worse though, about 3000rpms this time.
I have cleaned the TPS connections and reset TPS, its at .977 with throttle closed and 3.99 fully open. I also have the correct voltage and grounds coming in, no problems there. So I am to the point of thinking I need to replace the TPS. Anyone have any other ideas before I drop $45?
Thanks!
Thanks!
